Введение
If you have been using your Corsair Dark Core RGB Pro SE mouse for a while and noticed that it's becoming unresponsive or the clicks are not working properly, it could be due to worn-out mouse nano-switches. This guide will provide you with step-by-step instructions on how to replace the mouse nano-switches of your Corsair Dark Core RGB Pro SE.
Выберете то, что вам нужно
Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
Remove the two screws from the bottom of the mouse using a T5 Torx screwdriver.
Use an iFixit opening tool to gently pry up the right and left click buttons on the top cover of the mouse until they pop out of place.
Using a plastic opening tool, gently pry up the side button assemblies until they pop out of place.
Remove the screws that hold the circuit board in place using a Phillips #0 screwdriver.
Gently lift the PCB and set it aside.
Инструмент, используемый на этом этапе:Tweezers$4.99
