Введение
This guide walks through how to replace a broken key switch for a Corsair K95 RGB Platinum mechanical keyboard.
A key switch on a mechanical keyboard is the mechanism under the key caps that register when an individual key is pressed. When a key stops functioning correctly, may it be incorrectly actuating or not working, it could be due to a damaged key switch. These problems may also be due to dirt and dust interfering with the switch, so we recommend cleaning your keyboard prior to starting this guide.
It is important to note that this fix involves soldering and desoldering. We recommend going over this guide if you are unfamiliar with how to solder or desolder a connection.
Ensure that your keyboard is unplugged before beginning.
Выберете то, что вам нужно
Desolder the connection of the broken switch.
Flip the board over.
Remove the broken switch.
2 участников успешно повторили данное руководство.
