Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
Align the sewing machine at the upper left corner of the buttonhole.
Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
Start sewing. Sew to your second line.
Set your button hole dial to two.
Sew the bar tack at the bottom of the buttonhole.
Set your buttonhole dial to three.
Sew up the second side of your buttonhole, stopping at your top mark.
Set your buttonhole dial to four.
Sew the top bar tack at the top of the buttonhole.
Set your buttonhole dial to five.
This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
Clip the threads, freeing the fabric from the machine.
Clip any extra loose threads.
4 участников успешно повторили данное руководство.
2 Комментариев
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
