Crock-Pot Express Crock Multi-Cooker Heating Element Replacement
Выберете то, что вам нужно
  1. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Power Cord: шаг 1, изображение 1 из 1
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 2, изображение 1 из 1
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 3, изображение 1 из 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 3, изображение 2 из 2
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
  4. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: шаг 4, изображение 1 из 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: шаг 4, изображение 2 из 3 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Lid: шаг 4, изображение 3 из 3
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  5. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement, Heating Element: шаг 5, изображение 1 из 1
    • Remove the inner pot and set it aside for reassembly.
  6. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 6, изображение 1 из 1
    • Carefully rotate the Crock-Pot so that the bottom is facing upward, allowing access to the electrical panel.
    • Remove the two 12.4 mm screws with a Phillips #2 screwdriver.
  7. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 7, изображение 1 из 1
    • Rotate the electrical panel cover counter clockwise and pull up until the panel comes free.
  8. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 8, изображение 1 из 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 8, изображение 2 из 2
    • Remove 3 nuts, 3 washers, 3 spacers, and 3 lock washers using an adjustable wrench to free the heating element from the Crock-Pot housing.
  9. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 9, изображение 1 из 1
    • Remove the 10mm screw and metal plate beneath the electrical nodes using a Phillips #2 screwdriver.
  10. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 10, изображение 1 из 1
    • Remove the 2 red wires from the terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as red.
    • Remove 1 white wire from terminal post by unscrewing the 10mm screw using a Phillips #2 screwdriver and label terminal post as white.
  11. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 11, изображение 1 из 1
    • Reorient the crockpot on its side to prepare for the heating element removal.
  12. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 12, изображение 1 из 1
    • Carefully pull the heating element out and rotate it until bottom side is facing up out of the pot.
  13. Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 13, изображение 1 из 2 Crock-Pot Express Crock Multi-Cooker Heating Element Replacement: шаг 13, изображение 2 из 2
    • Remove both 19mm screws from the cutout switch housing using a Phillips #2 screwdriver, freeing the heating element from the device.
    • Carefully remove the heating element from the device.
Заключение
3 человек успешно провели ремонт по этому руководству.
William Kelly
Участник с: 09/24/18
817 Репутация
Автор 7 руководств
2 Комментарии к руководству
where do you get a heating element?
Stephanie Brown - Ответить Поделиться
Ma machine j'ai acheté neuf et elle s'allume pas
MOHAMED DJA YAHIA - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 28
За последние 30 дней: 103
За всё время: 5,893
