Введение
The Battery on a DJI Mini 2 drone can easily be replaced! This guide will show you how to quickly and safely remove the battery from the drone.
The battery of the drone powers the drone during it flights and is the heaviest part of the drone. If the battery is damaged in some way this will cause the drone to not turn on and require the battery to be replaced.
Face the DJI Mini 2 away from you so that you are looking at the charging ports.
Use your finger to open up the back panel.
Pinch the locking mechanism on the battery to release the lock.
Pull the battery straight out of the compartment.
3 участников успешно повторили данное руководство.
