DJI Phantom 2 Vision+ Propellers Removal
Выберете то, что вам нужно
  1. DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: шаг 1, изображение 1 из 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: шаг 1, изображение 2 из 3 DJI Phantom 2 Vision+ Propellers Removal, Remove the battery: шаг 1, изображение 3 из 3
    • Pinch the top and bottom tabs of the battery case, pull the battery straight out to remove it.
    • The metal connectors form a stiff mechanical connection with the battery, you will need quite a bit of force to remove the battery. Hold the Phantom Vision+ with one hand and remove the battery with the other.
  2. DJI Phantom 2 Vision+ Propellers Removal, Propellers: шаг 2, изображение 1 из 1
    • Determine if the propellor is clockwise or counter-clockwise rotating.
    • Each arm is labeled with a rotation icon that shows the direction of propellor rotation.
    • If this icon is missing or you can't read it, you can determine the direction of rotation by examining the propellor.
    • A clockwise rotating propellor pushes air down while rotating clockwise, and the opposite is true for a counter-clockwise rotating propellor, and the propellor blade slopes up in the direction of rotation.
  3. DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: шаг 3, изображение 1 из 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: шаг 3, изображение 2 из 3 DJI Phantom 2 Vision+ Propellers Removal, Removing clockwise rotating propellers: шаг 3, изображение 3 из 3
    • Loosen a clockwise rotating propeller by holding the motor with one hand and spinning the propellor clockwise.
    • Remove the propellor.
  4. DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: шаг 4, изображение 1 из 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: шаг 4, изображение 2 из 3 DJI Phantom 2 Vision+ Propellers Removal, Removing counter-clockwise rotating propellers: шаг 4, изображение 3 из 3
    • Loosen a counter-clockwise rotating propeller by holding the motor with one hand and spinning the propellor counter-clockwise.
Заключение
5 человек успешно провели ремонт по этому руководству.
David Hoyt
Участник с: 04/09/10
4 053 Репутация
Автор 41 руководств
Команда
Cal Poly, Team 25-89, Amido Spring 2010 Участник Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 членов
Автор 61 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 24
За всё время: 7,342
