Введение
Replace or upgrade your Phantom motors. This guide requires soldering.
Each motor's direction is determined by the order of its leads on the ESC, so when you're replacing, be sure to match the original order. Motors on opposite arms will have the same direction, so check the other arm for reference.
If you're ordering a replacement, be sure to get the right thread direction for your motor, or the propellor collet will loosen during flight.
Выберете то, что вам нужно
Press down on battery door release tab to flip the battery door open.
Silver-topped propeller collets unscrew counter-clockwise
Black-topped propeller collets unscrew clockwise
For propellors with silver collets: Use a 12 mm wrench or socket to loosen silver collets in the counter-clockwise direction.
Once free, unscrew and remove the collet.
For propellors with black collets: Use a 12 mm wrench or socket to loosen black collets in the clockwise direction.
Gently press down the motor shaft and lift the propeller up to remove it.
Remove the following screws from the underside of the drone:
Twelve 2.0 mm hex screws
Four Phillips #0 screws
Loosen the cable from the plastic landing gear.
Unplug the magnetometer molex connector.
Lift up on the top portion of the shell and set it on its side.
Lift the GPS cable molex connector up out of its socket on the main board.
Gently pull the slack of the magnetometer cable through the case bottom shell.
The case top shell should now have enough slack to work on the interior of the Phantom.
Desolder all three motors wires from the speed controller board.
Follow our soldering guide to learn how, or just to brush-up on your skills.
Unscrew the four 2 mm motor hex bolts from the case bottom shell.
9 человек успешно провели ремонт по этому руководству.
