Введение
If your device does not properly hang to the bottom of compatible Dell monitors, you may need to replace one or both of its hangers.
Выберете то, что вам нужно
Use a Jimmy to peel off the screen stuck to the front of the speaker.
Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
Lift the front panel off of the rest of the device.
Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
Remove the front panel from the device.
Remove the screws from the hangers you are looking to replace using a JIS #1 screwdriver.
