Dell Alienware 18 Hard Drive Replacement
Выберете то, что вам нужно
  1. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Disconnect the hard-drive cable from its connector on the system board.
  2. Dell Alienware 18 Hard Drive Replacement, Loosen the Screws: шаг 2, изображение 1 из 1
    • Loosen the captive screws that secure the hard-drive assembly to the computer base.
  3. Dell Alienware 18 Hard Drive Replacement, Lifting the Hard-Drive Assembly: шаг 3, изображение 1 из 1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: шаг 4, изображение 1 из 2 Dell Alienware 18 Hard Drive Replacement, Disconnecting the Interposer: шаг 4, изображение 2 из 2
    • Disconnect the interposer from the hard drives.
    • NOTE: Your computer supports up to three drives.
  5. Dell Alienware 18 Hard Drive Replacement, Remove the Screws: шаг 5, изображение 1 из 1
    • Remove the screws that secure the hard drive(s) to the hard-drive bracket and slide the hard drive(s) out of the hard-drive bracket.
  6. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive: шаг 6, изображение 1 из 1
    • Place the NEW primary hard drive in the hard-drive bracket.
  7. Dell Alienware 18 Hard Drive Replacement, Sliding the Secondary Hard-Drive: шаг 7, изображение 1 из 1
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  8. Dell Alienware 18 Hard Drive Replacement, Secure the Screws: шаг 8, изображение 1 из 1
    • Replace the screws that secure the primary hard drive to the hard-drive bracket.
  9. Dell Alienware 18 Hard Drive Replacement, Replace the Screws: шаг 9, изображение 1 из 1
    • If applicable, replace the screws that secure the secondary hard drive to the hard-drive bracket.
  10. Dell Alienware 18 Hard Drive Replacement, Connecting the Interposer: шаг 10, изображение 1 из 1
    • Connect the interposer to the hard drives.
  11. Dell Alienware 18 Hard Drive Replacement, Placing the Hard-Drive Assembly: шаг 11, изображение 1 из 1
    • Place the hard-drive assembly in the computer base.
  12. Dell Alienware 18 Hard Drive Replacement, Tightening the Screws: шаг 12, изображение 1 из 1
    • Tighten the captive screws that secure the hard-drive assembly to the computer base.
  13. Dell Alienware 18 Hard Drive Replacement, Connecting the Hard-Drive: шаг 13, изображение 1 из 1
    • Connect the hard-drive cable to its connector on the system board.
Финишная прямая
2 человек успешно провели ремонт по этому руководству.
darrius
Участник с: 03/26/18
5 213 Репутация
Автор 30 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
45 членов
Автор 1 998 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 14
За последние 30 дней: 51
За всё время: 1,252
