Введение
Use this guide to replace the CPU in a Dell Inspiron 1525.
Инструменты
Запчасти
Детали не указаны.
Slide the battery release switch away from the lock symbol until you hear the battery click.
Slide the battery towards the back of the laptop until it comes free.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
Gently lift the heat sink from side indicated in the picture.
Use a small flathead screwdriver to turn the ZIF-socket cam screw counterclockwise until it can't be turned anymore.
Lift the CPU out of its socket, being careful not to bend its pins.
3 участников успешно повторили данное руководство.
