Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through removing and replacing your Dell Inspiron 17R-N7110 hard drive. You will be handling and working with delicate electronic components, so be sure to wear the anti-static wrist strap for this replacement.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Anti-Static Wrist Strap$7.95
Place the laptop on a flat surface with the Dell logo upside down.
Flip the laptop over. The battery will be in the top center.
Slide both the left lock and right lock, towards the center of the battery.
Push upwards on the grip on the bottom of the battery to remove it.
Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
Tilt the metal jimmy away from you to pry up the edge of the keyboard.
Repeat the previous actions on each of the other three holes to release the keyboard.
Flip up the black flap where the keyboard cable connects to the motherboard
Gently pull the cable away from the slot to release the keyboard.
Remove the keyboard from the device.
Flip the laptop over so it is bottom-up.
Use a Phillips #0 screwdriver to unscrew the fifteen 5mm screws pictured.
Use a Phillips #0 screwdriver to unscrew the four 5mm screws from the palmrest.
Flip up the black flaps over the three cables pictured and gently pull them out.
Use a plastic opening tool to pry up the edges of the palmrest cover.
Pull off the palmrest cover. You will hear some popping sounds.
Use a Phillips #0 screwdriver to unscrew the two 5mm screws holding the hard drive.
Slowly lift up on the left side of the hard drive and pull to the left.
16 участников успешно повторили данное руководство.
5 Комментариев
Good guide, but missing a step. In the one I disassembled, the optical drive needed to be removed (it just slides out), and two screws that were holding in the keyboard needed to be removed before the keyboard would come out.
Yes that step is ESSENTIAL. Had I known that, I’d have saved 15 minutes as I tried to remove the top cover without destroying my client’s laptop. Really unfortunate to not have that step included NOW, it really can’t be isolated in the comments.
frank -
