Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Using a plastic opening tool, pry the front silver bezel away from the colored plastic shell.
Unscrew the two screws using a Phillips #00 screwdriver from the metal casing that retains the screen.
Pull down the laptop's back, keeping the screen upright, held in place by two metal strips going along its sides.
Unscrew the 4 screws from the two strips.
Disconnect the cord connecting the screen to the rest of the laptop. The cable will be attached to the screen using tape, so it can be safely removed. The actual cord connection is at the circuit board.
Insert the webcam module so that the 2 screw holders match up with the 2 holes in the module
Carefully connect the white cable running along the back of the screen to the appropriate docking station in the webcam module.
