Введение
This guide will demonstrate how to remove and replace you CPU.
Выберете то, что вам нужно
Remove the battery prior to working on any internal components.
Remove the twelve 6mm Phillips screws from the bottom of the case.
Gently pry away the silver bezel above the keyboard and below the display using a spudger.
Remove the two 5mm Phillips screws retaining the keyboard.
Pull the keyboard up and toward the monitor to reveal the ribbon cable beneath.
Firmly grasp the blue tape attached to the keyboard ribbon cable connector and pull upward away from the motherboard.
Firmly grasp the blue tape attached to the LCD display ribbon cable connector and pull upward away from the motherboard.
Remove the two 5mm Phillips screws holding the display hinge on both sides of the laptop.
Remove the seven 6mm Phillips screws holding the trackpad/palm rest to the motherboard.
Gently pry the CMOS battery out of its retaining clip using a spudger.
Remove the low profile connector for the keyboard status lights located next to the video card heat sink using a spudger.
Remove the trackpad ribbon cable from the motherboard using a spudger.
Loosen the four silver Phillips screws in a criss-cross pattern retaining the heatsink to the cpu.
Gently loosen but do not remove the flathead screw.
Lift the CPU away from the motherboard, taking care to not damage the gold pins.
