Выберете то, что вам нужно
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Flip the green fan cover up towards you to reveal the CPU heatsink.
Lift the heat sink release lever
Remove the heat sink from the CPU and lift it out.
Carefully release the ZIF socket - push the lever backwards to release it from the hold down tab and lift it up and to the left until it stops (roughly 90 degrees).
Gently lift the CPU straight up and out of the socket. There should be no resistance.
The CPU will only fit into the ZIF socket in one orientation so take care when reinserting it. make sure that pin A1 is located correctly
6 участников успешно повторили данное руководство.
