Dell Precision T3400 Optical Drive Replacement
  1. Dell Precision T3400 Optical Drive Replacement, Power down the PC.: шаг 1, изображение 1 из 1
    • If your PC is on, shut it down by navigating to the window tab in the bottom left corner, selecting the power icon, and then selecting shut down.
    • Unplug the PC from the wall.
    • Disconnect the power cable from the tower, unplug keyboards, monitors, or any other devices, and remove any USB devices.
    • Press the power button after completely shutting down the PC. This will "ground" the motherboard, preventing any short circuiting from occurring.
    Спросите у FixBot
    Добавить комментарий
  2. Dell Precision T3400 Optical Drive Replacement, Remove the computer's side panel.: шаг 2, изображение 1 из 2 Dell Precision T3400 Optical Drive Replacement, Remove the computer's side panel.: шаг 2, изображение 2 из 2
    • Lay the computer on its side so the panel faces up.
    • Push the cover release latch at the back of the computer's case. The cover should pop off and away from the computer.
    • Make sure the computer is on its side before you begin replacing any parts.
    Спросите у FixBot
  3. Dell Precision T3400 Optical Drive Replacement, Remove the front plate: шаг 3, изображение 1 из 1
    • Lift the front plate release lever, located toward the front of the PC.
    • While holding the front plate release lever up, slide the front plate towards the top of the case and remove it.
    Спросите у FixBot
  4. Dell Precision T3400 Optical Drive Replacement, Remove the drive faceplate: шаг 4, изображение 1 из 1
    • Remove the drive faceplate by pulling down on the blue plate latch. The faceplate will pop off.
    Спросите у FixBot
  5. Dell Precision T3400 Optical Drive Replacement, Disconnect the power and system board cables from the drive: шаг 5, изображение 1 из 1
    • Disconnect the power and system board cables from the back of the optical drive.
    • Pull on the connectors, not the wires, to remove the cables.
    Спросите у FixBot
  6. Dell Precision T3400 Optical Drive Replacement, Remove the optical drive from its bay: шаг 6, изображение 1 из 1
    • Slide the plate latch down again to release the screw
    • While holding the plate latch down, push the drive out from behind, then pull it out of the bay
    Спросите у FixBot
  7. Dell Precision T3400 Optical Drive Replacement, Slide the new drive into the now-empty drive bay: шаг 7, изображение 1 из 1
    • You should feel the drive click into place.
    Спросите у FixBot
  8. Dell Precision T3400 Optical Drive Replacement, Reconnect the optical drive cables: шаг 8, изображение 1 из 1
    • Connect both the power and the system board cables to the optical drive.
    • Don't forget to plug the system board cable into the system board!
    • Make sure cables are not in the way of any fans.
    Спросите у FixBot
Заключение
12 человек успешно провели ремонт по этому руководству.
Jenalina Santiago
Участник с: 09/08/13
1 426 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Участник UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 членов
Автор 14 руководств
6 Комментарии к руководству
That's a great help.
I didn't realize I need to remove the front panel first. I spent 15 minutes still could not remove the drive. After I read this guide, I got it done in less than a minute!
sfacp2 - Ответить Поделиться
Thanks for the help !!!
Alig0r
alig0r - Ответить Поделиться
I have a dell optiplex gx 270 and parts from a demension 2400 ..... Change component or drive
Liz Ballard - Ответить Поделиться
Plain and simple. Awesome! I knew I was missing a simple step (I didn't know the front plate had a release lever). With these steps, I was good in about 10 seconds tops.
Thanks!
davethemave1 - Ответить Поделиться
Thanks for your plane explanation.
Han Voerman - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 14
За последние 30 дней: 54
За всё время: 15,856
