Dell Streak 7 Headphone Jack Replacement
Выберете то, что вам нужно
  1. Dell Streak 7 Headphone Jack Replacement, Front Panel Assembly: шаг 1, изображение 1 из 1
    • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
    • You will want to heat up the screen edges with the iOpener to help facilitate removal.
  2. Dell Streak 7 Headphone Jack Replacement: шаг 2, изображение 1 из 1
    • Remove the button cover by lifting the cover away from the tablet.
  3. Dell Streak 7 Headphone Jack Replacement: шаг 3, изображение 1 из 1
    • Using the Torx screwdriver, remove the 4mm screws.
  4. Dell Streak 7 Headphone Jack Replacement: шаг 4, изображение 1 из 1
    • With the Torx screwdriver, remove the two 5mm screws.
  5. Dell Streak 7 Headphone Jack Replacement: шаг 5, изображение 1 из 2 Dell Streak 7 Headphone Jack Replacement: шаг 5, изображение 2 из 2
    • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
    • With the Torx screwdriver, remove the two 4mm screws.
  6. Dell Streak 7 Headphone Jack Replacement: шаг 6, изображение 1 из 1
    • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
  7. Dell Streak 7 Headphone Jack Replacement: шаг 7, изображение 1 из 2 Dell Streak 7 Headphone Jack Replacement: шаг 7, изображение 2 из 2
    • Ribbon cables are very sensitive and prone to breaking
    • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
    • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
  8. Dell Streak 7 Headphone Jack Replacement, Headphone Jack: шаг 8, изображение 1 из 1
    • Using the spudger, disconnect the ribbon cable by lifting up on the connector.
    • Ribbon cables are fragile and easily broken.
  9. Dell Streak 7 Headphone Jack Replacement: шаг 9, изображение 1 из 2 Dell Streak 7 Headphone Jack Replacement: шаг 9, изображение 2 из 2
    • Pull the headphone jack up, away from the case.
Заключение
Еще один человек закончил это руководство.
Ali Benjelloun
Участник с: 10/02/16
376 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 4-6, Passmore Fall 2016 Участник USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 152
