Выберете то, что вам нужно
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
Using the spudger, disconnect the ribbon cable by lifting up on the connector.
With the spudger, disconnect the antenna cable located on the module.
Using the spudger, disconnect the front camera by lifting up on the connector.
2 участников успешно повторили данное руководство.
Один комментарий
do you know any website or if you guys even sell the board to him
