Введение
Use this guide to replace the screen on your Dell Streak 7. This guide will show you how to remove the old display.
Выберете то, что вам нужно
Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
With the Torx screwdriver, remove the two 4mm screws.
Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
Pull out the ribbon cables through the opening in the metal cage.
Lift up the metal cage surrounding the screen by swinging the cage from one side.
2 участников успешно повторили данное руководство.
