Выберете то, что вам нужно
Use a metal spudger to remover the covers of each section that you removed screws from.
Once the cover is removed from the hard drive remove the hard drive by gently tugging it out.
Use the replacement guide for the fan to remove the fan.
You must first unscrew the screws holding the wire in place.
Unhook the wire that the metal spudger is pointing at.
Unplug the wires connecting the screen to the base.
The screen should come free and is able to be removed completely.
