Введение
Batteries slowly lose their ability to hold charge over time. If your battery will not charge or hold a charge, please refer to the Troubleshooting Page. If the problem persists, replace the battery by following the steps below. Make sure your laptop is turned off before starting this guide.
Выберете то, что вам нужно
Flip the laptop over so the vents are facing you.
Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
Pull the back cover off.
Flip up the clip of the ribbon connector.
Pull the strip out to disconnect the battery.
