Выберете то, что вам нужно
Slide the button next to the battery and lift up on the lip of the battery edge.
Remove the plastic trim at the base of the screen screen. Start from the tab on the right side and work to the left side.
Remove the keyboard by sliding it forward, off of the clips, and then lifting up.
Lift the keyboard about 2 inches up from the laptop platform.
From this angle the keyboard ribbon connector can be seen and disconnected.
Remove 2 M2x3mm screws that are located at the bottom of the plastic bezel with a PH0 screwdriver.
Use iFixit plastic tool and a cutout of cardboard to pry out the plastic bezel around the edges of the LCD screen
Disconnect the display connectors by removing them from the grooves and unplugging them.
Remove 12 M2x3mm screws along the edge of the screen frame with a PH0 screwdriver.
