Введение
This guide shows how to remove and replace the control module for the Dewalt Nailers DCN680D1 2018.
The module is an all-in-one assembly, which includes the trigger mechanism, battery connector, and selector switch board.
Выберете то, что вам нужно
Remove the following screws securing the outer housing:
Twelve T10 screws
One 2.5 mm hex screw
Carefully flip the device over.
Remove the left housing from the device.
Carefully remove the release button from the device.
Remove the button spring from the device.
Use a T20 driver to remove the two screws (one on either side) securing the back support .
Use a T10 driver to remove the three screws securing the motor wires
Use a small flathead screwdriver to pry up and disconnect the sensor connector from the side of the motor.
Insert the point of a pick tool into the push-in connector's inlet hole, which has the control module wire plugged into it.
With the pick tool still inserted, pull the red control module wire out of the push-in connector.
Repeat the previous two steps to disconnect the black control module wire from the push-in connector.
Lift and remove the control module from the device.
Reassembly tip: Make sure that the white plastic actuator latches into the black lever arm.
Remove the white plastic actuator from the control module and transfer it onto your replacement part.
When you install the actuator, make sure the actuator bar can press the white button on the control module.
Еще один человек закончил это руководство.
