Введение
If the DC power connector is broken this guide will teach you how to remove the broken component for replacement.
Выберете то, что вам нужно
Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
Desolder the back of the motherboard where the power connector is located.
