Введение
When working on replacing the Digiland DL1168A motherboard, it is important to keep in mind when working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. Common reasons for motherboard failure include excessive electrical shocks, increased heat, or physical damage to the device.
Выберете то, что вам нужно
Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
Desolder the four wires connecting the rear case to the motherboard.
Disconnect the wires from the motherboard.
Remove the rear case from the device.
Using the soldering iron, desolder all eight wires connected to the motherboard.
Removing the red wire then the black wire (2 wires).
Desolder the three wires and remove them.
Remove the single grey wire.
Remove the yellow and red twisted wires and black and red twisted wires connected to the speakers.
