Digital2 Platinum Pad 9 External Speaker Replacement
Выберете то, что вам нужно
  1. Digital2 Platinum Pad 9 External Speaker Replacement, External Cover: шаг 1, изображение 1 из 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 2, изображение 1 из 2 Digital2 Platinum Pad 9 External Speaker Replacement: шаг 2, изображение 2 из 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 3, изображение 1 из 2 Digital2 Platinum Pad 9 External Speaker Replacement: шаг 3, изображение 2 из 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 External Speaker Replacement, External Speaker: шаг 4, изображение 1 из 1
    • The external speakers are located in the black plastic fixture near the battery as pointed to in the image.
  5. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 5, изображение 1 из 1
    • Use a J0 sized Phillips head screwdriver to remove the two 3.175mm long Phillips head screws from the speaker fixture.
  6. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 6, изображение 1 из 1
    • Then lift up the cover holding the speakers down.
    • Remove the actual speakers along with the cover.
  7. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 7, изображение 1 из 1
    • Remove the tape holding the wires down.
  8. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 8, изображение 1 из 1
    • The two wires that connect the speakers to the motherboard must be removed next. In order to replace the speakers you will need to solder them back into place.
  9. Digital2 Platinum Pad 9 External Speaker Replacement: шаг 9, изображение 1 из 1
Заключение
David DeMeritt
Участник с: 03/08/16
637 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 5-6, Landers Spring 2016 Участник UMass Dartmouth, Team 5-6, Landers Spring 2016
UMASSD-LANDERS-S16S5G6
3 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 125
