Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Press the button found in the middle of the vacuum downwards. Then, separate the front from the back of the device by gently pulling apart.
Separate the front and the back and set the front aside.
Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
Unscrew each individual 13 mm screws from the vacuum with a micro screwdriver.
Once unscrewed, pull the case of the Dirt Devil Gator apart.
Remove the grey switch from the top of the device by pulling gently. Then, remove the complete motor by also pulling gently out of socket.
Remove the motor from your Dirt Devil Gator exterior by slightly pulling out the white motor.
Desolder each of the wires from the old circuit board, and solder them to the new circuit board in the same orientation.
Еще один человек закончил это руководство.
