Disabling the touch function
Выберете то, что вам нужно
  1. Disabling the touch function, Disabling the touch function: шаг 1, изображение 1 из 1
    • First disconnect all the cables to avoid doing some damage to both player and yourself.
    Спросите у FixBot
    Добавить комментарий
  2. Disabling the touch function, Open the case: шаг 2, изображение 1 из 3 Disabling the touch function, Open the case: шаг 2, изображение 2 из 3 Disabling the touch function, Open the case: шаг 2, изображение 3 из 3
    • At the back of the Player you'll find 4 #2 Phillips screws.
    • Once undone you can slide the case ca. 1,5cm towards you.
    • Now carefully pull the sides of the cover away from the body and lift the cover up.
    Спросите у FixBot
  3. Disabling the touch function, Deactivate the touch: шаг 3, изображение 1 из 1
    • Now there are two possibilities:
    • Either you want to see everything and have some tools, then you can use step 4 and 5.
    • Or you don't, then you go to step 6.
    Спросите у FixBot
  4. Disabling the touch function, The scenic route 1/2: шаг 4, изображение 1 из 3 Disabling the touch function, The scenic route 1/2: шаг 4, изображение 2 из 3 Disabling the touch function, The scenic route 1/2: шаг 4, изображение 3 из 3
    • Just be sure, you have disconnected the white ribbon from the mainboard, so you wouldn't damage the connector while taking the front cover off.
    • Now you have to get the metal spudger and gently work you way below the clips on the side and loosen them.
    • Then the ones at the top but careful, there are two left and right of the disk tray looking a bit different and consisting entirely out of snappy plastic.
    • Now the front cover will tilt forward.
    • Either you take the lower clips of as well, but the entire cover might jump towards you (in this case you have to make sure again, the blue ribbon is disconnected) or you just work with the gap you just created.
    Спросите у FixBot
  5. Disabling the touch function, The scenic route 2/2: шаг 5, изображение 1 из 3 Disabling the touch function, The scenic route 2/2: шаг 5, изображение 2 из 3 Disabling the touch function, The scenic route 2/2: шаг 5, изображение 3 из 3
    • Now you can take the spudger and open the little black clip on the connector holding the brown touch sensor ribbon.
    • Then just pull the brown ribbon out carefully and you are done.
    Спросите у FixBot
  6. Disabling the touch function, The Shortcut: шаг 6, изображение 1 из 1
    • Get the spudger and lift the small black clip on the white connector where the brown touch control ribbon is connected to the board.
    • Gently pull the brown ribbon out of the clip.
    Спросите у FixBot
  7. Disabling the touch function, Reassemble everything: шаг 7, изображение 1 из 1
    • After you have worked the magic don't forget to reconnect the white ribbon.
    • Now twist the cover back on. Twist, because it might need some gentle force to get through the last couple of millimeters.
    • Now your HT-E5550 will no longer unwantedly cycle through the sources or open and close the disc tray. The downside is that the touch-controls won't work either.
    Спросите у FixBot
Заключение
Thank you for trying. I hope it helps you as much as the fix helped me.
14 человек успешно провели ремонт по этому руководству.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Karsten
Участник с: 04/23/14
995 Репутация
Автор 3 руководств
6 Комментарии к руководству
you are awesome my friend, thanks.
Sa Gi - Ответить Поделиться
That issue has been annoying the crap out of me for months now. Fingers crossed this works, but so far so good….
Awesome instructions by the way (even if it doesn’t work)
William - Ответить Поделиться
Super! Hat funktioniert, läuft auch beim HT-D5200 wie hier beschrieben einwandfrei.
Michael Gallob - Ответить Поделиться
super du bist der beste
Reinhold Membarth - Ответить Поделиться
Hallo, vor Jahren hatte ich das Problem mit dem HT E5500 Samsung mitgeteilt. Hatte mir dann einen neuen Blu ray Spieler gekauft.
Hatte die Anlage jetzt neu in Betrieb genommen, stört noch genauso, fährt die Schublade raus. Habe das Gerät geöffnet und das Kabel entfernt.
Mich wunderte es nicht, das die Platine Fehlfunktionen hatte.1. Sind auf die Platinenbahnen Papieraufkleber, diese können den Schutzlack angreifen und einen Übergangswiderstand auslösen. Der Schutzlack ist teilweise am pröseln, wirklich eine schlechte Qualität. Die Basisplatinen sehen gut aus. Aber bei den Displayplatinen hat man gepfuscht. Jürgen Löw
Jürgen Löw - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 67
За всё время: 15,245
