Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Выберете то, что вам нужно
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Take out the four screws that keep the bottom of the hinges attached to the base.
5 участников успешно повторили данное руководство.
