Disassembling DualShock 4 Motherboard Assembly
Выберете то, что вам нужно
  1. Disassembling DualShock 4 Motherboard Assembly, Controller: шаг 1, изображение 1 из 1
    • Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
    • Be careful loosening the screws, using the wrong sized screwdriver, or letting the screwdriver slip can permanently damage the screw heads, making removal extremely difficult.
    Спросите у FixBot
    Добавить комментарий
  2. Disassembling DualShock 4 Motherboard Assembly: шаг 2, изображение 1 из 3 Disassembling DualShock 4 Motherboard Assembly: шаг 2, изображение 2 из 3 Disassembling DualShock 4 Motherboard Assembly: шаг 2, изображение 3 из 3
    • Four fragile plastic clips hold the casing together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Beginning with the left handle:
    • Pinch the left handle of the controller to introduce an opening.
    • Wedge a plastic opening tool into the opening and slide it up towards the joystick.
    • Pull down on tool to pry open the casing.
    • Repeat these steps for the right handle.
    Спросите у FixBot
  3. Disassembling DualShock 4 Motherboard Assembly: шаг 3, изображение 1 из 3 Disassembling DualShock 4 Motherboard Assembly: шаг 3, изображение 2 из 3 Disassembling DualShock 4 Motherboard Assembly: шаг 3, изображение 3 из 3
    • Wedge a plastic opening tool into the case-splittings and pull down to crack open the casing near the following buttons:
    • Share button
    • Options button
    • Split the plastic covers of the controller apart, taking note that they will still be attached by circuit board ribbons.
    • Three small pieces are often released from the framework. To prevent loss, maintain a controlled work field.
    • 2 Trigger Springs
    • 1 Grey Reset Button Extension
    Спросите у FixBot
  4. Disassembling DualShock 4 Motherboard Assembly, Disassembling DualShock 4 Motherboard Assembly: шаг 4, изображение 1 из 1
    • Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
    • Do not forcefully loosen the screw, as it may amount to permanent damage of the threads, making removal impossible.
    Спросите у FixBot
  5. Disassembling DualShock 4 Motherboard Assembly: шаг 5, изображение 1 из 2 Disassembling DualShock 4 Motherboard Assembly: шаг 5, изображение 2 из 2
    • Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
    Спросите у FixBot
  6. Disassembling DualShock 4 Motherboard Assembly: шаг 6, изображение 1 из 2 Disassembling DualShock 4 Motherboard Assembly: шаг 6, изображение 2 из 2
    • Carefully dislodge the motherboard assembly from the front cover.
    • Vibration motors are loosely attached to the motherboard assembly. Provide support at the two ends to ease the separation.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
    Спросите у FixBot
  7. Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: шаг 7, изображение 1 из 3 Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: шаг 7, изображение 2 из 3 Disassembling DualShock 4 Motherboard Assembly, Disassembly Complete: шаг 7, изображение 3 из 3
    • Successful disassembly of the controller will result in the following three parts, respectively:
    • Motherboard Assembly
    • Front Cover
    • Rear Cover
    Спросите у FixBot
Заключение
162 человек успешно провели ремонт по этому руководству.
Maaz Hussaini
Участник с: 01/21/14
6 023 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 6-21, Maness Winter 2014 Участник Cal Poly, Team 6-21, Maness Winter 2014
CPSU-MANESS-W14S6G21
4 членов
Автор 35 руководств
20 Комментарии к руководству
So my controller decided to stop charging (still stayed on until the battery completely dained) a couple weeks ago so I bought a new charging port and ribbon and replaced it put it all back together just for it to work the same not charging but on so I figured maybe it was the battery all along but this time I took my other new controller apart so I could test the battery by connecting it to the new controller to see if it will take charge which they would take charge on the new controller but when I took the new ones and put it in the old on it still wouldn't take charge I have no Idea what else to do everything else works it just won't charge even the light is still on but if I keep it connected to a USB cable it will stay on since the battery was dead but the battery status remains the same.
Archie Roberta - Ответить Поделиться
Same here except mine won't even work while plugged in. It just turns on and dies
Jonah Roeger - Ответить Поделиться
there is a new and different version out (looks the same) different internals - anyone got one to show us? (Model = CUH-ZCT1E?)
Russ - Ответить Поделиться
How do you put back the touchpad? That $@$* Is a &&^&^$^ paradox.
Modern Retro Gaming - Ответить Поделиться
The top of the touchpad that has the groove has to be inserted at the part where the bottom of the touchpad is normally. Then you you move it up and you can wiggle it through the arc. After that it fits snugly like it supposed to.
Rick - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 49
За последние 7 дней: 324
За последние 30 дней: 1,420
За всё время: 753,190
