Введение
In this guide, you will learn how to disassemble the motor housing cover.
Инструменты
Запчасти
Детали не указаны.
Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
This should be a 5/32 inch or 4mm punch.
My pin is stuck too, are there any other ways?
Can the pin be hammered from either side. It won’t budge
Just keep at it, mine didn’t budge for a while
No way. I ‘ve tried for an hour and it didn’t move at all. But I ‘ve found a solution. I drilled it out. First with 2mm then with a 3mm drill. Then I could easily remove it. The replace part is a 4mm x ~22.5mm grooved pin (half-length-center-grooved; ISO 8743).
Mine was also stubborn. I laid the machine on the side and sprayed WD-40 in the pin several times. Waited 30 min and then it came out easy.
Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
Using the same flathead screwdriver, remove the two 28 mm locking screws.
Classic Plus uses a square-drive screw. You’ll need #1 size.
Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
Carefully pull the power cord from the notch in back of the mixer.
For the KSM90BU model, take a set of needlenose pliers and carefully rotate the plastic clip 90 degrees, then pull the cord out of the notch.
Lift the motor housing cover from the mixer base.
Und wie komme ich nun an den Motor zur Reinigung des Unterbrechers?
ich habw eine 5KSM150, leider lässst sich die Motorabdeckung nicht entfernen, alle vorhergehenden Schritte wurden wie beschrieben erledigt
kann hier jemand helfen?
15 участников успешно повторили данное руководство.
Комментариев: 15
Well fine job! Just finished and t works!!!
Instruccion is exelent but I veleave the problem is electric. can you give aidea. dhe machine does’nt work at all
Thank you! I'm repainting my white mixer a deep cherry red gloss to match my kitchen. These mixers can last 20+ years, if you take care of them. But, who wants the same color kitchen for that long? Bonus: saved $50+ by painting it the color I wanted, rather than pay the extra for a mixer from the colored choices.
Do the motor housing sometimes become to hard to remove? I followed all the steps yet it still acts as if something inside the housing is keeping it from coming off.
Nothing else, only the planetary assembly, and the 9 big housing screws. Once those are off, it can take a lot of jiggling and persistence, mostly because there’s a vacuum between the vertical shaft and the bushing inside. Remember to loosen the cord in case to prevent yanking it accidentally when the cover comes off.
A gentle twist with a blade screwdriver in each of the control knob slots will start the separation.
Reassembly of motor housing onto base took a bit of patience, as it took a couple of minutes to line up the gears. You need to insert a punch or thin screwdriver in the shaft where you attach your beater or whip. Use the screwdriver to turn the shaft while pressing down gently on the top of the housing. Eventually the gears will align and the housing will lower into place. Then you can insert your fasteners, the planetary, and the planetary pin.
I followed your instructions and removed the top housing. The inside of my housing has “piles” of jelly like goo (I’m assuming it’s old congealed oil). What should the inside look like? Should I remove this oil? I looks like mushed up prunes. (sorry I couldn’t come up with a better comparison). My machine has been making a very loud humming/grinding noise when I run it.
The “goo” is the grease applied during assembly. The tv show “how its made” covered the assembly of these mixers, and they use a substantial amount of grease. Oil, on the other hand, will be thinner, and flow/run/drip. The grease will stay put or move really slowly.
Hi Chris, I’ve tried to remove the pin from the planetary gear cover, but it will not budge. Any suggestions? Thanks
Having the same problem, is there a solution to this?
I have got the same problem…
My model doesn’t seem to have the rear screws shown in Step 5?
What happens if I didn’t realize there was a locking washer on one of those rear screws and put it back together without it? The video I watched didn’t mention it until I already had the thing all put together again and then I didn’t see any extra washer lying around.. Until my husband found it on the floor… it was a bear getting the pin out of the planetary gear cover.
Unplug the Mixer.
Mike Reckner - Ответить
Good call! Nobody likes digital trauma
David Brand - Ответить
