Disassembling Kodak Easyshare C813 Front Cover
Выберете то, что вам нужно
  1. Disassembling Kodak Easyshare C813 Front Cover, Battery: шаг 1, изображение 1 из 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Front Cover: шаг 2, изображение 1 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 2, изображение 2 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 2, изображение 3 из 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Front Cover, Back Cover: шаг 3, изображение 1 из 1
    • Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Disassembling Kodak Easyshare C813 Front Cover: шаг 4, изображение 1 из 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Front Cover: шаг 5, изображение 1 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 5, изображение 2 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 5, изображение 3 из 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  6. Disassembling Kodak Easyshare C813 Front Cover: шаг 7, изображение 1 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 7, изображение 2 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 7, изображение 3 из 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  7. Disassembling Kodak Easyshare C813 Front Cover: шаг 8, изображение 1 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 8, изображение 2 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 8, изображение 3 из 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  8. Disassembling Kodak Easyshare C813 Front Cover, Front Cover: шаг 9, изображение 1 из 2 Disassembling Kodak Easyshare C813 Front Cover, Front Cover: шаг 9, изображение 2 из 2
    • Open the battery door.
  9. Disassembling Kodak Easyshare C813 Front Cover: шаг 10, изображение 1 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 10, изображение 2 из 3 Disassembling Kodak Easyshare C813 Front Cover: шаг 10, изображение 3 из 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  10. Disassembling Kodak Easyshare C813 Front Cover: шаг 11, изображение 1 из 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
Финишная черта
2 участников успешно повторили данное руководство.
Susan Marano
Участник с: 04/15/10
336 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 24-22, Regan Spring 2010 Участник Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 членов
Автор 20 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 3,798
