Disassembling Mac Powerbook 140 Keycaps
Выберете то, что вам нужно
  1. Disassembling Mac Powerbook 140 Keycaps, Takeing the caps off: шаг 1, изображение 1 из 1
    • The keycaps are connected via 2 clips on the left and the right side of the keycaps. Larger keycaps are connected to stabilizers, be careful when taking these caps off since the underlying plastic has overhangs that can break off.
    • Firstly pry the clip on one side with a spudger. Keep the open clip up while prying the other clip open. Be careful of the stabilizers when taking off larger caps.
    Спросите у FixBot
    Добавить комментарий
  2. Disassembling Mac Powerbook 140 Keycaps, Take off underlying parts: шаг 2, изображение 1 из 1
    • The board still has the white springs and the silicone cone on it. Grab the white spring with tweezers or by hand and take it off. It has 2 clips on the top and on the bottom.
    • After removing the white part remove the silicone cone with tweezers.
    Спросите у FixBot
  3. Disassembling Mac Powerbook 140 Keycaps, Putting the silicone rings back: шаг 3, изображение 1 из 1
    • First put the silicone rings on the circular pillars with a hole. Put the silicone rings with their widest part up.
    Спросите у FixBot
    • I found the easiest way to put these back is to put it on rotated to the left then spin it clockwise until it clicks.
    Спросите у FixBot
  4. Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: шаг 5, изображение 1 из 2 Disassembling Mac Powerbook 140 Keycaps, Putting the caps on: шаг 5, изображение 2 из 2
    • To correctly orient the keycaps note, that the letters are on the bottom left of the keycaps. Also, the caps are rounder at the bottom. You can find the place for the white spring's arms on the back side of the keycaps.
    Спросите у FixBot
Заключение
To reassemble your device, follow from the 3rd step.
Kristóf Kékesi
Участник с: 12/16/25
121 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 54
