Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
How to replace the spring loaded battery cover or the spring.
Выберете то, что вам нужно
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Pull both sides of the black piece upward-about a mm.
Once the piece is lifted carefully slide the screen out of the slot.
Unscrew the four (6mm) screws from the inner casing.
Pull the inner casing off.
If all the screws are out the casing will come off easily. If it doesn't check to make sure all the screws are completely out of the plastic.
From the other side pull the pin all the way out. The battery cover will fall off.
