Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part
Выберете то, что вам нужно
  1. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: шаг 1, изображение 1 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: шаг 1, изображение 2 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part, Sony Cyber Shot WX80: шаг 1, изображение 3 из 3
    • Remove all six #00 screws holding the outer chassis together with a Phillips #00 screwdriver.
    • Keep track of all screws as they are small and very easy to lose
  2. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 2, изображение 1 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 2, изображение 2 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 2, изображение 3 из 3
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Remove the front of the shell case with the spudger. Insert the spudger into the seam on the right side of the camera and pry away from the back case.
    • Using the spudger, repeat the process to remove the back of the case. Pry away from the front of the camera.
  3. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 3, изображение 1 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 3, изображение 2 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Turn the camera so that you are looking at the LCD screen.
    • Use tweezers to remove the first of two ribbon cables holding the LCD screen in place. Pull directly out of the port.
    • Use tweezers to remove the second of the two ribbon cables using the same method.
    • Take care not to tear the ribbons. They are the communication networks that your screen uses to operate.
    • The LCD screen is now detached. Gently pull it apart from the rest of the camera with your hands.
  4. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 4, изображение 1 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 4, изображение 2 из 3 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 4, изображение 3 из 3
    • Turn the side of the camera you just removed the cable ribbons from toward you.
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Remove the inner frame lining with tweezers.
    • Do so gently to avoid damaging the ribbon cable.
    • Carefully lift the inner frame lining away from the rest of the camera with your fingers.
  5. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 5, изображение 1 из 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 5, изображение 2 из 2
    • With the LCD screen removed, you should see a black metal plate. This can be pulled off to reveal the motherboard and the lens.
    • Use your fingers to gently lift the plate up and away from the rest of the camera.
  6. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 6, изображение 1 из 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 6, изображение 2 из 2
    • You should now be able to see the exposed motherboard and lens.
    • To separate the motherboard and lens, you must detach two more ribbon cables.
    • Remove the first ribbon cable (pictured first) with tweezers. Pull gently away from the camera.
    • Remove the second ribbon cable (pictured second) with tweezers. Pull gently away from the camera.
    • Use your fingers to gently lift the lens away from the motherboard and frame.
  7. Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 7, изображение 1 из 2 Disassembling Sony Cyber Shot WX80 Total Disassembling Part by Part: шаг 7, изображение 2 из 2
    • Remove the screw (pictured first) with the #00 Phillips screwdriver.
    • Use tweezers to remove the last ribbon cable (pictured second). Pull gently away from the camera frame.
    • You should now be able to remove the motherboard from the base skeleton frame.
Заключение
3 человек успешно провели ремонт по этому руководству.
Scott Grambo
Участник с: 04/08/15
288 Репутация
Автор 2 руководств
Команда
Eastern Washington University, Team 2-5, Matresse Spring 2015 Участник Eastern Washington University, Team 2-5, Matresse Spring 2015
EWU-MATRESSE-S15S2G5
4 членов
Автор 7 руководств
5 Комментарии к руководству
So what about the other parts not in your photos that fall ?
The bracket around the speaker and this little white part that fell out as soon as I lifted the back cover a little? can you please give more info
Kat - Ответить Поделиться
I'm also finding where was the white parts located. It seems that without this part, wx80 works well. If you found its location, please give me hint. Thanks.
Chung-Suh Ku - Поделиться
Maybe this helps for the location of the white part: https://www.quora.com/What-does-the-insi...
Christian Urban - Ответить Поделиться
This is not complete disassembly pics. Not at all. This is half the steps.
Mayur Panghaal - Ответить Поделиться
Huh?
How about the sensor? How do I clean the sensor?
jim dandy - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 19
За последние 30 дней: 59
За всё время: 3,536
