Disassembling Sony Ericsson w600i LCD Section
Выберете то, что вам нужно
  1. Disassembling Sony Ericsson w600i LCD Section, Disassembling Sony Ericsson w600i Battery Cover: шаг 1, изображение 1 из 1
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Disassembling Sony Ericsson w600i LCD Section, Battery: шаг 2, изображение 1 из 1
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Disassembling Sony Ericsson w600i LCD Section, Back housing: шаг 3, изображение 1 из 1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Disassembling Sony Ericsson w600i LCD Section: шаг 4, изображение 1 из 1
    • Swivel the phone open.
  5. Disassembling Sony Ericsson w600i LCD Section: шаг 5, изображение 1 из 1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Disassembling Sony Ericsson w600i LCD Section: шаг 6, изображение 1 из 1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Disassembling Sony Ericsson w600i LCD Section: шаг 7, изображение 1 из 1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Disassembling Sony Ericsson w600i LCD Section: шаг 8, изображение 1 из 2 Disassembling Sony Ericsson w600i LCD Section: шаг 8, изображение 2 из 2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Disassembling Sony Ericsson w600i LCD Section: шаг 9, изображение 1 из 3 Disassembling Sony Ericsson w600i LCD Section: шаг 9, изображение 2 из 3 Disassembling Sony Ericsson w600i LCD Section: шаг 9, изображение 3 из 3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Disassembling Sony Ericsson w600i LCD Section: шаг 10, изображение 1 из 1
    • The back housing is now disassembled, and the swivel assembly is revealed.
  11. Disassembling Sony Ericsson w600i LCD Section, LCD Section: шаг 11, изображение 1 из 2 Disassembling Sony Ericsson w600i LCD Section, LCD Section: шаг 11, изображение 2 из 2
    • Remove the four black Phillips screws holding the swivel assembly to the LCD section of the phone.
    • Be mindful of the screws, as they are very small.
    • The screws are Phillips, 2.4mm
  12. Disassembling Sony Ericsson w600i LCD Section: шаг 12, изображение 1 из 1
    • Gently remove the grey plastic cover at the top-rear of the LCD section with a spudger.
    • It is secured with adhesive tape, the more gently you remove this piece, the easier reassembly will be later.
  13. Disassembling Sony Ericsson w600i LCD Section: шаг 13, изображение 1 из 1
    • Remove the two Torx screws revealed under the grey cover.
    • The screws are Torx T5, 5.6mm
  14. Disassembling Sony Ericsson w600i LCD Section: шаг 14, изображение 1 из 1
    • Gently pry off the front face, starting at the bottom slot.
  15. Disassembling Sony Ericsson w600i LCD Section: шаг 15, изображение 1 из 1
    • Remove the Torx screws near the buttons.
  16. Disassembling Sony Ericsson w600i LCD Section: шаг 16, изображение 1 из 2 Disassembling Sony Ericsson w600i LCD Section: шаг 16, изображение 2 из 2
    • Remove the black front plate.
    • Remove the button overlay, taking note of its position for reassembly. There are small grey nubs that correspond to holes in the overlay.
  17. Disassembling Sony Ericsson w600i LCD Section: шаг 17, изображение 1 из 1
    • Gently release the small grey retaining clips around the outside of the display assembly.
    • Separate the display assembly from its backplate.
    • Take care; some of the side buttons may dislodge as the backplate is separated.
    • The LCD section is now disassembled.
Заключение
Еще один человек закончил это руководство.
Beau Blanchard
Участник с: 09/30/12
20 Репутация
Автор 6 руководств
Команда
University of Maine, Team 1-5, Diaz Fall 2012 Участник University of Maine, Team 1-5, Diaz Fall 2012
UMAINE-DIAZ-F12S1G5
1 член
Автор 12 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 799
