Dragon Touch M10X Battery Replacement
Выберете то, что вам нужно
  1. Dragon Touch M10X Battery Replacement, Battery: шаг 1, изображение 1 из 2 Dragon Touch M10X Battery Replacement, Battery: шаг 1, изображение 2 из 2
    • Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit.
  2. Dragon Touch M10X Battery Replacement: шаг 2, изображение 1 из 1
    • Use the large plastic opening tool to separate the back cover from the device. Wedge the sharp end of the tool into the crack and use leverage to further separate the back cover from the device.
    • Still holding pressure on the opening tool, slowly and carefully slide the tool along the gap to separate it further. You should hear slight snapping as it comes apart. Work your way around all sides until the cover is able to be removed.
  3. Dragon Touch M10X Battery Replacement: шаг 3, изображение 1 из 2 Dragon Touch M10X Battery Replacement: шаг 3, изображение 2 из 2
    • Using your hands and the separating tool, remove the back cover from the device.
  4. Dragon Touch M10X Battery Replacement: шаг 4, изображение 1 из 1
    • Using a plastic opening tool, carefully peel off the yellow tape holding the battery in place.
    • Unless you have more of this tape, you're going to need to save it and put it back on after you have successfully replaced the battery.
  5. Dragon Touch M10X Battery Replacement: шаг 5, изображение 1 из 1
    • This is the most difficult part. The battery is held onto the surface with a strong epoxy. The battery can be bent easily so extreme care must be taken in removing it from the surface. A plastic opening tool must be used to loosen the battery from the surface.
    • Once it is loose, it may be fully separated by using either your hands or the plastic opening tool.
  6. Dragon Touch M10X Battery Replacement: шаг 6, изображение 1 из 1
    • The red and white wires connecting the battery to the motherboard must be desoldered. Refer to the Soldering Technique Guide for instructions on how to do this. (Be sure to desolder the wires from the battery AND the motherboard.)
Заключение
3 участников успешно повторили данное руководство.
Joseph Rockcliffe
Участник с: 03/24/16
585 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-7, Catania Spring 2016 Участник UMass Dartmouth, Team 4-7, Catania Spring 2016
UMASSD-CATANIA-S16S4G7
3 членов
Автор 8 руководств
2 Комментариев
Why desolder the wires from the motherboard? Couldn't you just solder them to the new battery while they're still attached to the motherboard?
Also, what is the yellow tape for? Isn't it enough to just epoxy the new battery or does the tape serve some purpose, like maybe electrical insulation?
Kanon Kubose - Ответить
if the battery is not for sale, where do you get it?
raymondstapleton - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 8
За последние 30 дней: 41
За всё время: 8,700
