Введение
This project will result in an illustrated how-to guide on fixing a drawer roller bracket that does not close completely. By the end of this fix you will have a drawer that closes flush against the face of the furniture.
Выберете то, что вам нужно
Clear out drawer of any contents. This will make the drawer easier to handle, with no mess or clutter.
To remove, pull the drawer completely open.
Lift the drawer straight up.
Measure the length of the internal track to the recessed part in the rear of the track.
Then measure the amount of bracket that needs to be removed. In our case, 2 inches will need to be removed.
Remove the excess bracket. Make sure to remove parts of the bracket that do not contain holes. These holes are used for fasteners.
To cut a section, make sure you make perfectly vertical cuts for the remaining pieces to line up. To assure a straight line to cut, use a sharpie marker to mark a straight line.
Apply JB Kwikweld to the remaining pieces of bracket. Mix equal parts of the mixture.
Discard the removed piece from last step.
Use a drill with a drill bit to make necessary holes for screws to sit and fasten the bracket. Use a drill bit slightly larger than shaft of screws, but smaller than the head of the screws.
Install new fastener screws to the bracket.
Insert wheels on both sides of the drawer bracket into the opening behind the wheel on the track located in the furniture.
Close the drawer and make sure it opens and closes functionally.
Еще один человек закончил это руководство.
