Введение
Is your screen blanking out in the middle of your favorite scene? Replacing the screen may help.
Выберете то, что вам нужно
To remove the cover of the screen, the four rubber feet must be removed to expose four screws.
Lift out the rubber feet with tweezers or a spudger.
Remove the four screws underneath the rubber feet of the device.
The top two screws are 3.175 mm head, 4.762 mm length flat-heat screws.
The bottom two screws are 4.762 mm head, 6.35 mm length flat-head screws.
Using a plastic opening tool, lift off the screen cover from the screen and the top of the device.
Remove the black tape connecting the wires to the front cover.
The tape can be removed with tweezers or your fingers.
Remove the screen's ribbon cable by lifting the connecting flap with your fingers.
Gently pull out the ribbon cable with tweezers or your fingers.
Remove the black and white wires by desoldering them from the circuit board attached to the case.
