Dyson DC14 Power Switch Replacement
Выберете то, что вам нужно
  1. Dyson DC14 Power Switch Replacement, Power Switch: шаг 1, изображение 1 из 2 Dyson DC14 Power Switch Replacement, Power Switch: шаг 1, изображение 2 из 2
    • Start with your Dyson DC14 unplugged, standing upright and facing towards you.
    • Remove the canister from the vacuum.
    • Disconnect the telescopic vacuum wand.
    • Remove the two T15 Torx screws securing the switch cover to the vacuum.
    Спросите у FixBot
    Добавить комментарий
  2. Dyson DC14 Power Switch Replacement: шаг 2, изображение 1 из 2 Dyson DC14 Power Switch Replacement: шаг 2, изображение 2 из 2
    • Push outward on the two plastic clips that secure the switch cover to the vacuum.
    Спросите у FixBot
  3. Dyson DC14 Power Switch Replacement: шаг 3, изображение 1 из 1
    • Remove the switch cover from the vacuum.
    • The purple switch button may separate from the rest of the switch cover.
    Спросите у FixBot
  4. Dyson DC14 Power Switch Replacement: шаг 4, изображение 1 из 1
    • Holding them by their white plastic coverings, firmly pull the two wires from the power switch.
    • Be sure to grip the wires from their attached connectors. Pulling directly on the wires could damage your vacuum.
    • The terminals will only fit one way during reassembly. Only one of the wires is long enough to reach the far terminal of the switch.
    Спросите у FixBot
Заключение
19 человек успешно провели ремонт по этому руководству.
Zachary
Участник с: 10/06/12
318 Репутация
1 руководство автора
Команда
Cal Poly, Team 3-22, Amido Fall 2012 Участник Cal Poly, Team 3-22, Amido Fall 2012
CPSU-AMIDO-F12S3G22
4 членов
Автор 8 руководств
10 Комментарии к руководству
Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!
Tim Swift - Ответить Поделиться
The comment I listed below is not mine. I copied it from a Mr. Tim Swift who wrote it on 06/28/2015. Had I not have seen his comment, I would have said the exact same thing.
I have only one other thing to say......AWESOME!!
Bob Williams
robertvwilliams@comcast.net
"Thank you to the awesome student who made this tutorial! It worked perfectly and saved me the MAJOR expense of a professional repair. Great job!"
Robert Williams - Ответить Поделиться
I replaced my power switch. Easy! $15 part!
brdurham - Ответить Поделиться
Thanks from a 70 year old non-mechanical female with no torque wrench. I followed this tutorial a few months ago and found that my switch had simply come undone and I reinserted it but couldn't attach orange thing back cause switch kept slipping loose. I taped it up around switch so I wouldn't get electrocuted when turning on. Has worked fine til now, and I suppose my switch has finally failed, so I'm ordering new one. This Dyson was a refurbished one I got fairly cheap (for a Dyson) 12 years ago! SO, THANKS MUCH!!
Queenie - Ответить Поделиться
Brilliant and saved me over £100 which is the cost of a Dyson engineer to attend plus switch. Name a charity.
Tariq Rafique - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 57
За всё время: 39,425
