Dyson DC39 Origin Replacement
Выберете то, что вам нужно
  1. Dyson DC39 Origin  Replacement, Bin: шаг 1, изображение 1 из 3 Dyson DC39 Origin  Replacement, Bin: шаг 1, изображение 2 из 3 Dyson DC39 Origin  Replacement, Bin: шаг 1, изображение 3 из 3
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
  2. Dyson DC39 Origin  Replacement, Steering Assembly: шаг 2, изображение 1 из 3 Dyson DC39 Origin  Replacement, Steering Assembly: шаг 2, изображение 2 из 3 Dyson DC39 Origin  Replacement, Steering Assembly: шаг 2, изображение 3 из 3
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
  3. Dyson DC39 Origin  Replacement: шаг 3, изображение 1 из 3 Dyson DC39 Origin  Replacement: шаг 3, изображение 2 из 3 Dyson DC39 Origin  Replacement: шаг 3, изображение 3 из 3
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
  4. Dyson DC39 Origin  Replacement, Inlet Hose: шаг 4, изображение 1 из 2 Dyson DC39 Origin  Replacement, Inlet Hose: шаг 4, изображение 2 из 2
    • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
    • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
    • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
  5. Dyson DC39 Origin  Replacement: шаг 5, изображение 1 из 2 Dyson DC39 Origin  Replacement: шаг 5, изображение 2 из 2
    • Pull the inlet hose straight up from the steering assembly.
    • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
Заключение
5 человек успешно провели ремонт по этому руководству.
Michael Hutcheson
Участник с: 04/26/17
312 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S23-G6, Livingston Spring 2017 Участник Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 членов
Автор 6 руководств
1 Комментарий к руководству
Really clear instructions - thank you
collette - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 13
За последние 30 дней: 35
За всё время: 4,736
