Введение
If your Dyson V8 Animal’s battery fails to charge or turn the vacuum on, use this guide to replace the battery. The battery is used to power the vacuum. A broken or worn-out battery may fail to turn the vacuum on or charge.
Before using this guide check that your battery does not just need to be charged and refer to The Devices LED Flashes troubleshooting page for more information on troubleshooting your battery.
No special skills are required for this guide.
Before beginning, make sure to turn off the vacuum and disconnect it from any external power source.
Инструменты
Запчасти
Детали не указаны.
Push down on the red tab on the other side.
Pull the motor away from the handle.
Use a Phillips #0 screwdriver to remove two 18 mm screws on the bottom of the battery.
Use a Phillips #0 screwdriver to remove one 18 mm screw on the back of the handle.
Еще один человек закончил это руководство.
