Введение
While the power cord is built to last for quite a while, it can still suffer from wear-and-tear. Additionally, accidents that damage the power cord can happen. This guide covers how to replace the vacuum’s power cord.
Выберете то, что вам нужно
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Unscrew the 14mm PH2 Phillips head screw.
Pull the bottom cover off of the rest of the casing.
Unscrew the six 18.1mm PH2 Phillips head screws on the side of the vacuum.
Pull the casing apart.
