Введение
This repair video served as the inspiration for my guide. A big thanks to danliv99 from YouTube for helping me fix my glasses!
Выберете то, что вам нужно
These are the tools I used to insert the screw through the spring hinge. In the video a paperclip was used, but the paperclip I had on-hand could not fit into the tiny recess in order to jam the spring open.
The problem at hand: The screw will not fit through the arm because a spring is pulling on the hinge (and screw hole) in the arm.
Insert a pushpin through the hole and use it as leverage to extend the spring hinge outwards.
Once the spring hinge extends outward with the first pushpin, use a second pushpin to keep the hole in the "extended" position:
There will be a small notch revealed once the spring hinge extends outwards. Wedge the second pushpin into that notch so that the hinge doesn't go back inwards.
Инструмент, используемый на этом этапе:Tweezers$4.99
With the second pushpin hanging around, line up the eyeglass frame/arm holes together.
Use a pair of tweezers to insert your eyeglass screw through both holes.
Finally, use a 1.2 mm flat-blade screwdriver to secure the arm to the frame.
Presto-blamo! Your eyeglasses are fixed.
The same procedure can be used on sunglasses without any problems.
56 человек успешно провели ремонт по этому руководству.
32 Комментарии к руководству
It's kind of confusing. Is there any other simpler explanation?
Great post with informative guide. I really appreciated it. Thanks
