Введение
Every person has a natural growth cycle, just like hair. Natural lashes shed anywhere from 60-90 days, replacing themselves with new ones.
Fixing grown-out eyelash extensions is necessary every 2-3 weeks to keep your eyelashes looking full.
This repair guide is necessary for eyelash technicians to ensure a safe and proper eyelash extension fill procedure. Eyelash extension fills are a great opportunity to refine the client’s look based on what look they are going for. It is also a great opportunity for the lash technician to express their creativity.
Выберете то, что вам нужно
Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
Make sure that the client feels comfortable with the tape on with their eyes closed.
Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove all the grown-out lashes using the banana peel method.
Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
Put a drop or two of the eyelash primer on the micro swabs.
Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
