Введение
Although a non-functioning screen would be hard to manage with this device, replacing the LCD screen is relatively easy.
Выберете то, что вам нужно
Using 1.5mm Hex Screwdriver, remove two 3.0 mm hex screws on the front of the camera.
Using Phillips #00 screwdriver, remove two 3.0 mm screws on the bottom of the front face.
Using Phillips #00 screwdriver, remove 3.0 mm screws on the bottom of the camera closer to the back.
Using Phillips #00 screwdriver remove two 3.0 mm screws on the back of the camera. This will remove the eyelet for the camera strap and the rear cover.
Using 1.5mm Hex screwdriver, remove 3.0 mm hex screw on top edge of silver panel.
Using Phillips #00 screwdriver, remove 3.0 mm screw on bottom edge.
Once both screws are removed the silver side casing will slide off.
Unlatch the four clasps located on each side of the camera by hand.
The fourth clasp is concealed by the battery door. To reach the clasp see Fujifilm FinePix XP50 Battery Replacement for instructions.
Using Phillips #00 screwdriver, remove seven 3.0 mm screws.
Remove the remaining five 3.0 mm screws which hold the rear case and the control panel together.
The rear panel is now free from the camera.
Take the spudger and wedge it in between the screen and the frame.
Slowly make your way around the screen with the spudger just enough to separate the screen from the frame.
Take the spudger again and wedge it in the thinner frame to pry the LCD screen from the frame.
Make your way around with the spudger just enough to separate the screen and frame once again.
Take the spudger and wedge it very carefully between the LCD screen and the very thin and fragile frame.
