Введение
In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the motherboard . This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera. After removing the LCD screen, there awaits only a few more screws to detach from the RF shield and motherboard.
Выберете то, что вам нужно
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Rotate the camera so that the HDMI port is facing up.
Remove the two 5.0 mm JIS #000 screws.
Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
Press the pop-up button highlighted in the picture to release the flash mechanism.
Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
Gently tilt the the lock for the ZIF cable attached to the motherboard with a plastic removal tool.
Pull the ZIF cable from motherboard using tweezers.
In order to free the motherboard, detach the wires by desoldering.
Detach the soldering between the camera and motherboard by desoldering.
For instructions on desoldering see How To Solder and Desolder Connections
Еще один человек закончил это руководство.
