Full method - HP Touchsmart IQ506 CMOS Battery Replacement
Выберете то, что вам нужно
  1. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Unplug the system: шаг 1, изображение 1 из 2 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Unplug the system: шаг 1, изображение 2 из 2
    • Unplug the system from the power brick.
  2. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the Wireless keyboard receiver: шаг 2, изображение 1 из 1
    • READ: I did not get the original keyboard with my system and the receiver mine came with was broken. Since the HP OEM keyboard is NLA, I installed a USB hub to use another keyboard.
    • To remove the back cover from the system, the keyboard receiver must be removed. To do this, pull the receiver by the notch to release it. Once you do this, it should come out of the internal USB port to free the back cover.
  3. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the RAM door: шаг 3, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the RAM door: шаг 3, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the RAM door: шаг 3, изображение 3 из 3
    • Remove the screw on the RAM door. Once you remove the screw, unclip the door.
  4. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Legacy iFixit driver ONLY - how to access the screws on the top: шаг 4, изображение 1 из 1
    • (Legacy iFixit driver only): The top hinge screws can be difficult to get to. If you have the classic iFixit screwdriver handle, lock the stand upright and slide it under the stand from the rear to access the top screws. This should not be needed with the 64-bit Manta driver or EET handle. Remove the bottom screws as normal.
  5. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the stand: шаг 5, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the stand: шаг 5, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the stand: шаг 5, изображение 3 из 3
    • It may be easier to remove the top screws from the stand first due to their placement.
    • Remove the stand from the system. Use a Phillips #1 screwdriver to loosen the 4 screws.
  6. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the I/O panel screws: шаг 6, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the I/O panel screws: шаг 6, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the I/O panel screws: шаг 6, изображение 3 из 3
    • Remove the 3 screws in the I/O bay of the system.
    • Remove the 2 screws from under the RAM panel. Note: My system is missing a screw, but it is marked accordingly. Yoy may or may not need to keep this in mind.
    • Remove the 2 screws from under the ODD cover. Tip: If you are having trouble with this cover, use a spudger or plastic pry tool to remove it.
    • NOTE: ONE SCREW NOT SHOWN DUE TO PHOTO LIMIT. Remove the 2 screws above the model number palte.
  7. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the screws from the system 2: шаг 7, изображение 1 из 2 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the screws from the system 2: шаг 7, изображение 2 из 2
    • Remove the 2 screws by the feet on the system chassis.
  8. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the back from the system: шаг 8, изображение 1 из 1
    • If you have difficulty removing the back of the system, a spudger may help you release the tabs.
    • Remove the back from the system. The quickest way to do this is to start from the bottom and then unsnap the sides.
  9. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield: шаг 9, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield: шаг 9, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield: шаг 9, изображение 3 из 3
    • The metal EMI shield over the power jack has to be removed to pull the motherboard shield off. This must be replaced when reassembling the system.
    • Remove the 7 screws to reveal the motherboard and other major components. Use a Phillips #1 screwdriver to do this.
  10. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield 2: шаг 10, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield 2: шаг 10, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the motherboard shield 2: шаг 10, изображение 3 из 3
    • Remove the 6 remaining screws from the motherboard shield. Use the same Phillips #1 screwdriver as you used the first time.
  11. Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the battery: шаг 11, изображение 1 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the battery: шаг 11, изображение 2 из 3 Full method - HP Touchsmart IQ506 CMOS Battery Replacement, Remove the battery: шаг 11, изображение 3 из 3
    • If you want to track when you replaced the battery, put a mark on the battery with the month and year so you know when it was replaced. If you cannot write on the battery, putting a hidden note under the memory panel is also an option.
    • Optional: Put a note on the RAM door out of sight or write when the battery was replaced on the new battery.
    • Push the tab on the battery in and then remove it. Put the new battery in the reverse way of removal. Once this is done, write when the battery was replaced (Example: 5/16) on the battery.
Заключение
Nick
Участник с: 11/10/09
93 686 Репутация
Автор 59 руководств
Команду
Master Techs Участник Master Techs
Community
327 членов
Автор 1 699 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 2,046
