Введение
Follow this guide when the agitator in your GE top-load washer is damaged or when you must remove it to reach the hub or the 7⁄16-inch transmission bolt hidden underneath. The procedure relies on a hidden alignment hole and takes only basic hand tools once you know the trick.
Выберете то, что вам нужно
Шаг 1 Open the washer and expose the agitator
Raise the lid to give full access to the agitator assembly.
Шаг 2 Identify the alignment hole in the agitator base
Look for the small round hole located at the very bottom of the agitator skirt.
Шаг 3 Align the agitator hole with the internal nipple
Feel around the agitator base until you find the raised nipple on the washer plate.
Rotate the agitator until its hole lines up directly over the nipple.
Шаг 4 Lock the agitator with a Phillips screwdriver
Insert a Phillips screwdriver through the hole and press firmly until it bottoms out.
Шаг 5 Stabilize the tub to avoid spinning
Have a helper hold the washer tub steady so it cannot rotate while you twist the agitator.
Шаг 6 Twist and lift the agitator off the drive
Grip the agitator housing and turn it clockwise until it breaks free from the drive tabs.
Lift the agitator straight up and out of the tub once it releases.
Шаг 7 Optional removal of the agitator plate
If you need hub access, remove the central 7⁄16-inch bolt with a socket wrench and lift off the plate.
Шаг 8 Position the new agitator on the drive tabs
Align the four slots on the agitator base with the four plastic retention pieces on the washer plate.
Lower the agitator onto the tabs until it sits flush on the plate.
Шаг 9 Lock the new agitator in place
Twist the agitator clockwise until it snaps and will not rotate freely.
Шаг 10 Reinstall the dispenser cap
Press the fabric-softener dispenser cap back onto the agitator top.
The agitator is now secure and the washer is ready for use. Knowing about the hidden alignment hole makes future hub or tub repairs straightforward.
