Garmin Vivoactive Battery Replacement
Выберете то, что вам нужно
  1. Garmin Vivoactive Battery Replacement, Wristband: шаг 1, изображение 1 из 1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
  2. Garmin Vivoactive Battery Replacement: шаг 2, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 2, изображение 2 из 2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
  3. Garmin Vivoactive Battery Replacement, Display Unit: шаг 3, изображение 1 из 1
    • Place a heated iOpener over the display to loosen the adhesive.
    • After about a minute, the iOpener may be removed.
    • For more in depth instructions on using the iOpener, refer to the iOpener guide.
  4. Garmin Vivoactive Battery Replacement: шаг 4, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 4, изображение 2 из 2
    • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
  5. Garmin Vivoactive Battery Replacement: шаг 5, изображение 1 из 1
    • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
    • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
    • Insert it a minimal distance to avoid damaging internal components.
  6. Garmin Vivoactive Battery Replacement: шаг 6, изображение 1 из 1
    • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
    • Do the same on the opposite side of the device until you have a good grip of the screen.
  7. Garmin Vivoactive Battery Replacement: шаг 7, изображение 1 из 1
    • Obtain a careful grip of the screen from two of its sides.
    • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
  8. Garmin Vivoactive Battery Replacement: шаг 8, изображение 1 из 1
    • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
    • Upon completing this step, the screen should be free from the rest of the device.
  9. Garmin Vivoactive Battery Replacement, Battery: шаг 9, изображение 1 из 2 Garmin Vivoactive Battery Replacement, Battery: шаг 9, изображение 2 из 2
    • Follow previous guides until you've exposed the battery as shown.
    • Begin by removing the battery connector tab.
    • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
  10. Garmin Vivoactive Battery Replacement: шаг 10, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 10, изображение 2 из 2
    • Use a plastic opening pick to gently pry out the battery as shown.
    • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
  11. Garmin Vivoactive Battery Replacement: шаг 11, изображение 1 из 3 Garmin Vivoactive Battery Replacement: шаг 11, изображение 2 из 3 Garmin Vivoactive Battery Replacement: шаг 11, изображение 3 из 3
    • With the battery loose from the case, rotate it to expose the attached tab
    • Gently pry up the attached tab with a fingernail.
    • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
Заключение
16 участников успешно повторили данное руководство.
Michael Clark
Участник с: 10/01/15
658 Репутация
1 руководство автора
Команда
Cal Poly, Team 1-21, Maness Fall 2015 Участник Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 членов
Автор 17 руководств
28 Комментариев
But battery buy where?
sanborn - Ответить
I have the Same question... where can i buy the replacement?
Roli - Ответить
I've tried everywhere to find a battery for my vivoactive, with no luck. Where should I look to find a battery? HELP!
David -
Battery is a 3.7 V, 150 mAh Li-Polymer type.
Gary K - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 30
За последние 7 дней: 148
За последние 30 дней: 608
За всё время: 104,576
