Введение
The continual use of the Vivoactive power button and action key may lead to dysfunctional buttons. This problem can be solved with the replacement of the buttons themselves to ensure all components are working correctly.
Выберете то, что вам нужно
Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
Gently push the strap's pin out. It will begin to protrude from the other end.
Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
Place a heated iOpener over the display to loosen the adhesive.
After about a minute, the iOpener may be removed.
Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
Do the same on the opposite side of the device until you have a good grip of the screen.
Obtain a careful grip of the screen from two of its sides.
Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
Upon completing this step, the screen should be free from the rest of the device.
Follow previous guides until you've exposed the battery as shown.
Begin by removing the battery connector tab.
With the battery loose from the case, rotate it to expose the attached tab
Gently pry up the attached tab with a fingernail.
Remove the four 2.4 mm screws with a PH00 Phillips head screwdriver.
Use the spudger to pry up the board from the case.
Wiggle the exposed side of the board from each end until it comes free.
Orient the crescent shaped retaining clip so the open section faces the bottom of the device.
Remove the retaining clip by pulling up away from the device with the precision tweezers.
